It is currently Mon Aug 18, 2025 12:33 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2  Next
PostPosted: Thu Apr 03, 2014 8:49 pm
I just wonder if I should go with 800 rather than 1200 for any reason?
And what kind of off-the-shelf unit could I use for controlling temperature? I'm struggling to find something.
Thanks in advance for any advice,
Nick
These users thanked the author Nick Royle for the post: keenovo (Wed May 07, 2014 11:56 pm)
PostPosted: Thu Apr 03, 2014 9:00 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Nick, you might want to PM Fred Tellier about controllers. He's helped quite a few people, and he is a really good guy!
Alex
PostPosted: Thu Apr 03, 2014 9:04 pm
Thanks, Alex! Will do. :)
PostPosted: Fri Apr 04, 2014 3:41 pm
I think I'm going to order it tonight. 1200 watt must be ok or there wouldn't be demand? Guess it'll just speed up the process.
PostPosted: Fri Apr 04, 2014 4:00 pm
First name: Larry
Last Name: Hawes
My blanket, from Omega, was rated at 10 watts and I could have gotten a 5 watt model so I'm a bit confused about 800 - 1200 watt heating blankets.
I just looked again at the Omega specs ad noticed it's 5 or 10 watts per sq inch so not sure how that relates. I got the 10 watt PSI and it very hot very very fast - will smoke itself pretty quickly if not watched carefully..
Thank You and Best To All
PostPosted: Fri Apr 04, 2014 4:03 pm
First name: Larry
Last Name: Hawes
Easiest off the shelf temp controller is a router speed controller from Harbor Freight.
http://www.harborfreight.com/router-spe ... 43060.html
PostPosted: Fri Apr 04, 2014 4:09 pm
These are they...
http://www.ebay.co.uk/itm/Keenovo-Silicone-Heater-Heating-Blanket-Guitar-Side-Bender-6-X-36-800W-220V-/271396127432?pt=UK_MusicalInstr_Access_RL&hash=item3f307842c8
http://www.ebay.co.uk/itm/Keenovo-Silicone-Heater-Heating-Blanket-Guitar-Side-Bender-15-95cm-1200W-220V-/281264981600?pt=UK_MusicalInstr_Access_RL&hash=item417cb30660
36 inch by 6 inch = area of 220ish, divide the 1200 by that and it seems like the 1200 watt is 5 per square inch... Or is that 10? Electronics is not something I tend to touch to often.
Would you say the 10 is overkill? Or just advising to be careful with it?
I may have to get one of those harbor freight ones. Can't find them over here. Maybe I'm not looking right.
Thanks for the help, Larry!
PostPosted: Fri Apr 04, 2014 4:27 pm
First name: Larry
Last Name: Hawes
I really like the blanket i have and couldn't imagine having only half the power. It's a bit like horsepower, can't really have too much but you have to be more careful. So to answer your question more directly, no I don't think the 10 is overkill.
PostPosted: Fri Apr 04, 2014 4:35 pm
Awesome. Cheers, Larry!
Now to work out if I got that maths right. I hope the 1200 is 10w psi!
EDIT: No, it looks like it's definitely is 5w psi. So thank goodness I risked overposting and asked! The hunt continues....
PostPosted: Fri Apr 04, 2014 5:36 pm
Larry, I just checked on Omega, and they don't list a 10w psi 6 x 36" blanket... What size did you get?
http://i.ebayimg.com/t/Keenovo-Silicone-Heater-Blanket-6-X37-4-1-2KW-220V-w-Rainbow-Thermostat-0-200-C-/00/s/MTA1NlgxNTg0/z/tLAAAOxy4fVTFHYp/$_58.JPG
I can get that with it for 12 quid extra. Should be as good as the router controller but only goes up to 200 degrees C (392 fareingheit).
PostPosted: Fri Apr 04, 2014 6:32 pm
First name: Larry
Last Name: Hawes
That site is very hard to navigate for me. It's been a very long time and can't recall what I ordered or what I got. Sorry I can't be of any more help.
PostPosted: Fri Apr 04, 2014 7:23 pm
No worries at all, Larry, thanks for all your help! I'll hold off on ordering a little longer!
Cheers,
Nick
Anyone else using a 5 watt per square inch one happily?
PostPosted: Sat Apr 05, 2014 6:18 am
If IIRC the blanket I use is 2.5 W /sq.in. and it works fine. I think many people use the 5 watt blankets. In the U.S. household voltage is 110v, so a 10w blanket could potentially draw over 18 amps - exceeding the recommended limit for many branch circuits. In England with 220v circuits the amperage may not be a concern (what gage wire is used for branch circuits there?).
The 5w blanket might be easier to find a controller for also.
PostPosted: Sat Apr 05, 2014 8:51 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
That is not a temperature controller, it will control the amount of power to the blanket but does not control the temperature, you must do that by monitoring the temperature. A temperature controller uses a thermocouple to monitor and adjust automatically to the temperature you have set then will hold it within a couple degrees of the set temperature.
I also added a timer to my controller box as sometimes a person can get distracted and might forget the controller is still heating the wood, 15 minutes is plenty long enough to bend and set a side.
Fred
Fred Tellier
PostPosted: Sat Apr 05, 2014 10:43 am
Cool, thanks, Clay! That makes m'mind up! I don't know what gauge wire we use. If i need something wired, I call a mate! :lol:
Fred
Thanks Fred, Does this rainbow controller fit the bill?
PostPosted: Tue Apr 08, 2014 6:06 pm
Last Name: Beaver
City: Lake Forest
It does look like the Rainbow has a thermo coupler. I assume the dial is used to set heat in Celsius. If those are true it should work as a controller... how good of a controller? That would be the question. The kind I am use to shows the actual temp and the set temp in a digital display. That does give you a better feeling for what is going on.
Joe Beaver
Maker of Sawdust
PostPosted: Tue Apr 08, 2014 6:37 pm
Thanks for the input, Joe! That's kinda what I figured. I bought it anyway. For £12 it's worth a shot! Was dispatched yesterday.
Cheers!
PostPosted: Wed Apr 09, 2014 2:44 am
Definitely interested in how you get on with this blanket, as I have been considering one myself
Nick
Follow my musings on getting started in luthiery http://www.tredwellinstruments.co.uk
PostPosted: Wed Apr 09, 2014 3:59 am
First name: Shane
Last Name: Woonton
City: Wellington
Country: New Zealand
Cheers!
And Nick please let us know how that controller goes. I've been looking for something in 220v that doesn't cost an arm and a leg.
Cheers,
PostPosted: Wed Apr 09, 2014 7:41 pm
Will do, Shane, no worries!
PostPosted: Wed Apr 09, 2014 8:44 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
building a blanket controller is easy, look up some of Freds posts...mine consists of a pid controller, ebay for about 35 bucks , 20 amp solid state relay, thermocouple wire , cheap timer and a regular 110 outlet..
MK5acoustics.com
PostPosted: Wed Apr 09, 2014 8:51 pm
Very neat. Lucky you didn't post before I bought it or my brother would've given me an even harder time for not making it myself! Mine was only £12 though!? If it works well, it will have saved some dough.
(Thinking about it, I probably didn't do enough searching about the controller, just asked. My bad.)
PostPosted: Mon Apr 28, 2014 5:51 pm
Hi All,
I got back from holiday a couple of days ago and the blanket arrived today. It's porbably a couple of weeks before i can test it but here are some pics for now...
£72 on eBay direct from Keenovo - free delivery took just less than 3 weeks.
I still need to put a plug on it. The controller seems good to me, if it works well. The thermometer connection is a bare silver wire, I don't know if that's usual or what?
The controller worked out to £12, so I don't mind if I have to buy another one. I thought it was worth the gamble. As soon as I've made my bender and mould, I'm going to give it a full test and I'll report my findings.
Would love to hear any thoughts from those who were waiting to see what I thought of it.
PostPosted: Mon Apr 28, 2014 6:22 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
I'd be interested to see if this works too. Just been thinking about upgrading to a bending machine myself. Where did you find that controller though? The only one from keenovo I can find on ebay is this one for £60... http://www.ebay.co.uk/itm/Digital-PID-C ... 417fc23b91
Pablo Picasso
Users browsing this forum: DennisK and 11 guests
